OSPFv3.ProtoMgr.AllocRepHndlFail
Description
A replication handle could not be created for a control block. The Control Block will be destroyed. If this operation was triggered by a MIB command then the MIB signal will be returned with a failure code. This may cause some configuration information to have to be resent. Alternatively if this operation was caused by an OSPF protocol exchange then the packet that triggered it will be dropped.
Remedy
Investigate the source of the failure. It is probably due to a resource shortage.
Severity
Warning
Message Text
%p2% failed to allocate a replication handle for control block type %p1%.
Message Parameters
Name Type
p1 xInt32
p2 String
